1 - 8 of 8 Posts
Unable to change S-KTRC setting? Stuck on 1
Just picked up a gen 5 and trying to learn the dash. The S-KTRC setting is at 1 but I'm unable to change it when I'm in the setup mode. It skips it completely. What am I missing?
:dontknow:
Discussion Starter · #3 ·
Should just hold the krtc button and it will cycle through the levels, I think. Not aware of needing to be in a menu. I've been wrong before though.
There's a ktrc button? Going back in the garage to check.
Discussion Starter · #4 ·
Couldn't find any said button.
Discussion Starter · #6 · (Edited)
It's in the owners manual
I read it already. But just reread it and going to try again. I kept trying to do it in the set up but after rereading it, I just use the up and down button.
Discussion Starter · #7 ·
Figured it out. Thanks.
I know Rainking12 figured it out, but for those wondering:
Apply pressure on the "up" or "down" button on the left handlebar controls. Keep pressing it for roughly 2 seconds then release.
If you press the down button, the KTRC number will go up (increasing KTRC restrictions).
1 - 8 of 8 Posts
