I'm looking at spending around $6k to get my gen 2 engine built for top speed/track day racing. Mostly focusing on top speed, but I'd like it to be linear enough to use on the twisties..
What would be the best bang for the buck at this point?
These are my plans so far:
1. electric water pump
2. gen 3 oil pump (turns slower)
3. gen 3 crank (2# lighter)
4. smoothed throttle bodies (second butterflies removed/smoothed)
5. custom cams (plan to send bike to (The Official Site, Compton Customs)
6. decked head, thinner head gasket, running race gas
7. 2mm overbore, new pistons, new lighter rods
8. bazzaz quick shift, and afm module
The suspension has been fully redone with a customized Penske triple clicker rear, and revalved and resprung rebuilt front forks from Traxxion, and a rebuilt/modified steering damper. I'm already running some light weight components, ceramic wheel bearings, 520 race chain/sprockets, modded airbox, hiflow race filter, pc3 with quick shift and custom tune. Also have one piece race tail, tubular subframe, new levers, rearsets, and riflemans quick throttle, tre, ecu flash to remove top speed limit, raise red line 500, full akropovic titanium exhaust, titanium axle nut, ti caliper bolts, ti rotor bolts, ti sprocket nuts, shortened axle, light rear rotor, custom underslung and miniature rear brake, small reservoirs, ignition switch delete, keyless gas cap, R1 monobloc calipers, stainless lines. All sound dampening and the air injection system has been removed.
Is there anything else that I should be doing, or shouldn't do? Would I gain anything by going to larger valves? Does anyone know of a better airbox for more volume? With s. TX high heat would I gain much by insulating the carbon tank and airbox? What about a lower first gear, or would that just make it harder to keep the front wheel down?
I know lighter wheels would really help, I'm trying to find a used set of carbon wheels, currently running light slick tires..
The goal is over 200 in the standing mile, which doesn't seem too difficult, but I weigh 230 plus gear (easy to drop muscle, but part of my job is being in good condition).
opcorn:
