Hey all
Uk bike zx10r 2005 has the grey wire / resistor symptoms ( irregular non starting , cranks over but won’t fire , eventually after like various attempts will start )
when it starts runs fine , it’s just getting it ti start
It doesn’t fire on any cylinders just turns over when cranking so it’s as if all 4 pots don’t get fuel / spark
nothing changes then after like so many failed attempts randomly it will fire
everything possible changed - no difference
cam sensor
Crank sensor
Amplifier
Key
Airbox sensor
Coolant sensor
Fuel pump
All wiring checked
Starter solenoid
Diode mod on starter trigger switch
Power commander removed
Cold start linkage adjusted
Coils
came across the U.S issue of resistor in ignition switch ( underneath it ) and the symptoms when this fail are same as mine
problem is the Uk bike doesn’t have this resistor it has its own immobiliser system factory fitted
wondering if I put this resistor in it may cure the fault ????
cam sensor
Crank sensor
Amplifier
Key
Airbox sensor
Coolant sensor
Fuel pump
All wiring checked
Starter solenoid
Coils
