Two Brothers Racing is known mainly for their exhaust systems, but we found their S1-Pro Stand to be a nifty piece of kit that’s perfect for those that just have to have a premium stand under their motorcycles. The S1 Pro Paddock Stand is made with a CNC mandrel bent .049 stainless steel handle that has a pair of TIG welded inserts on its ends for attaching it to the riser plates. The risers themselves are manufactured using CNC-machined aluminum pieces to which a pair of adaptors are mounted to accept the spools of most late-model motorcycles. But this stand does more than look good. 80mm polyurethane rollers are strategically located for a solid stance when holding your bike up. The rollers themselves are mounted within a set of precision roller bearings for a grease-on-glass feeling when lifting or lower your motorcycle.
Best of all, Two Brothers paddock stands are available with black, red, gold, green or blue accents to match your taste.
If you’re looking for a premium paddock stand for a showpiece motorcycle, call Mike at 866.931.6644 ext 804 or send an email to FORUM at RIDERSDISCOUNT dot COM with TWO BROS PADDOCK STAND in the subject line and we’ll get back to you right away.
The S1 Pro Paddock Stand in black. MSRP $329.95
High-quality stainless steel hardware is used to assemble the aluminum risers for a lifetime of corrosion-free good looks.
Spool adaptors are machined to be light and strong.
80mm wheels are mounted on roller bearings for smooth action when raising or lowering your back on the stand.
And don’t forget, Two Brothers Stands come in your choice of five different colors.
