1 - 10 of 10 Posts
What you guys make of this master cylinder? Write up as below, from Harris Perfomance.
This is a twin lever master cylinder that incorporates 2 master cylinders. It has the added advantage of being able to be mounted either side of the handlebar. For left hand side mounting, it can be used as a hydraulic clutch and rear brake and for right hand side mounting; it can be used for the front brake and also the rear brake. A very clever design allows for easy operation of both levers simultaneously.
Both levers are fully adjustable for span and ratio. It has two inlets for the fluid reservoir so when mounting on either side; it has an inlet for the brake fluid reservoir on the top of the unit. Therefore the unused inlet on the underside is automatically sealed off. It was designed and produced after much demand from the racing paddock and disabled riders. Available in either polished or black anodised finish
Chickenstrip Eater
Dunno, would you want a long ass break line runnin all the way back to the rear brake? I could see the advantages though, get rid of the rear MC, RES, and lever. HOW MUCH?
Retired post whore
The stunting crowd will definitely dig that piece. A little too blingy for a stunt bike though.
At $1200 thats your complete front brake system minus calipers. AP Racing MC, any brakeline you want, pads, and wave rotors. That's a bit ridiculous not to mention ugly as hell.
That's only silly if you have both your hands. I have a buddy who recently lost his arm in a bike accident (Fail-to-yield-cager).... he'd love to get something like this when he gets back into the game.
...imagine that; a good use for it.
1 - 10 of 10 Posts
