1 - 5 of 5 Posts
Anyone have any trouble with turn signals???????????Mine quit working I am wondering if it has something to do with clear alternatives integrated tail light??I checked fuse,so it's not that.Any help is appreciated
Rent this space
If you used the scotchlock connectors that came with the kit, I would check there.
There is a shared ground for the rear too, so if left and right dont work check the ground.
i had this problem at first. you probably just need to ground the circuit (usually the black wire)
THEY HAVE BEEN WORKING THEY JUST QUIT.if it was the ground on taillight wouldn't the front work????I am wondering if maybe it is the flasher,but if that is what it is they would come on just not flash.I put the other flasher they sell to slow down the blinking.Roger
1 - 5 of 5 Posts
