1 - 9 of 9 Posts
any suggestions on a heavy duty clutch and springs ????????????
Hayes Billet basket.......Barnette or EBC springs........stock fibers and steels....KO combo
Cheapest route: have the rivets on your stock basket welded. You're not going to be drag racing, just street roll-ons. Never heard of the GSXR springs, that sounds nice and cheap. You can install 3 heavy and 3 OEM, probably all you need for 6psi. If it slips in high gear, add more spring.
Ordered a set of heavy duty springs . and gotnna use stock friction plates and steel plates till they go thanks guys prob do the weld on the rivits good idea
rivets are too skiny, they will still break even if you weld them, get an 04-05 jadder spring and it'll make 2nd gen clutch feel so much better.
In my 2010 zx10 drag bike I run brocks springs with spacers, cycle concepts drag pak and hays billet basket. pretty much a bullet proof clutch setup.
1 - 9 of 9 Posts
