1 - 7 of 7 Posts
I have a little problem with my transmission. After shifting gears the shifter doesn't completely return fully to its normal position. I gotta 'help it a bit' before I can shift again. Example: after shifting up, I have to tap the shifter slightly down with my toe in order to shift up again. Has anyone ever run into this before or even heard of it before?
Thanks for any info anyone can provide.
a common issue with the 08's
fixed for the 9
Im wondering the same. What was changed in the '09's to remedy the problem? Just so I don't run into the same problem down the road when I fix it.
1 - 7 of 7 Posts
