1 - 8 of 8 Posts
Well I think I may have a bent tranny shift fork or worse :BangHead: My 05 will "pop" out of first gear only when under a "load"...If you creep around in first no problem, but pickup the throttle (not hard or fast) when the RPM's build pop goes the weasel. I was wondering before I teardown and inspect if anyone knows should/can I go with aftermarket (or are there aftermarket shift forks available) vs. OEM?? BTW it has 11,500 miles never had a problem shifting, false neutral, or anything of the type. Thanks.
Discussion Starter · #4 ·
Do you have to pull the motor to change the shift forks? I could have sworn I read a thread that someone said you could change them without pulling the motor or splitting the cases, but I can't find it anywhere now????
Premium Member
'16 ZX-10R KRT
You'll need to inspect the shift drum as well. My ZX-7R had the same issue and it turned out that the shift forks were worn, but straight. The shift drum had a corner of one of the grooves rounded off where the shift forks ride in and because if this the bike would not stay in second gear. I replaced the shift forks anyway, the drum, and had the gear train indexed and undercut while I had it all apart. But the shift drum was the problem and I had the other stuff done while the tranny was apart.
Premium Member
'16 ZX-10R KRT
the job will be much easier if you pull the motor. You'll have to split the crankcase apart to get to the tranny components. You won't be able to do anything by just pulling the oil pan unfortunately. It's not a hard job, just time consuming and you need to stay organized and patient.
1 - 8 of 8 Posts
