1 - 4 of 4 Posts
hey i need to know the voltage range for the tps from 0 % and then also 100% throttle and the color of wire i should tap into for a signal
i am wanting to install a daytona wego III wideband that i just bought off the site thanks
The TPS wire at the ECU you will need to tap into is a yellow/white wire. You can check the voltage between the yellow/white and the brown/black wire at the ecu. I believe pin 26 and 34 i think. Voltage should be about 0.6 at idle to about 3.9 at WOT. Hope that helps.
When you tap into it you can go into the wego and see what its putting out and then adjust the parameters as such:thumbsup:
thanks guys also would it be possible to just tap into the power commander tps signal instead of the factory harness and if so what wire lol thanks
1 - 4 of 4 Posts
