Got a 2017 ZX10 with Guhl flash on the ECU and a PCV had on dyno TPS was reading 97% at idle was wondering what the gray wire on the PCV that you tap on the purple wire #20 pin on ECU does if this wire is for TPS. Has anyone else ran into this ? Also the fuel table was flashed for 3/4 exhaust system PCV has a zero map in it ?
Bike did make pretty good power has Akrapovic exhaust BMC street filter block off plates made 186 HP and 80 ft lbs torque SAE numbers
Map was little rich was going to have the tuner adust it that's when noticed the TPS reading 97% at idle
