Make less work for yourself and keep your bike dust-free simply by having it safely covered when you’re done riding for the day. Tour Master Elite motorcycle covers are 100% waterproof and built to last with a 300D Carbolex chassis that has double-stitched and taped seams so it won’t tear easily when you put it on or take it off. Some waterproof covers actually trap moisture, increasing the likelihood of corrosion and negating the point of putting a cover on in the first place! Tour Master Elite covers easily ventilate moisture, so you won’t pull it off to find your bike covered in water droplets. For protection of bodywork, the windshield and tail section areas of the bike cover are built using a soft “protector fabric” which is designed to play nicely with the bike’s bodywork and won’t scratch it up. Finally, unlike many motorcycle covers, you don’t have to wait until your bike cools off before putting the Elite cover on thanks to aluminized heat panels that keep the cover from melting in the areas where hot exhausts and engine cases are most commonly found.
It’s easy to keep your bike looking new and hold a higher resale value with this quality motorcycle cover. Tour Master Elite Motorcycle Covers are available on our website where you can choose between four different sizes to suit your motorcycle. If you have any questions, you can always call us at 866.931.6644 ext 817 and talk to TJ for expert sizing help.
When not in use, these bags have a storage pouch to keep them clean.
