Guys,
is is ok to run the bike when the oil window is completely filled (bike standing leveled and straight, of course) ?
Thanks alot
powerwheelies once in a while...or stand ups for miles at a time?but dont you put more oil in there if you do wheelies? isn't that a "protocol"?
:+1: drain some oil out out my man and :welcome: to the sitejust powerwheelies, i wouldn't add extra oil.
:+1: I always make sure my level is somewhere in the upper 2/3's of the window...Gen2 should take 4 QTs (w/ filter change) to the top of the window. No problem at this point, since "normal" mid window is about 3.9 QTs. Pretty much ok anywhere in the window.
If you really have a 1/2 QT extra in there you should let a little out. Be much easier to let out the filter, than the drain bolt.
