Fairing conection system. I hate you. You have managed to mass produce a house of cards taht makes oil changes far more difficult than they ought to be. The guy that did the 04-05 did a better job. Please go work for Suzuki. That is all.:fu2:
I don't know why you are having a problem..
I do not remove the fairings for an oil change..
Drain oil, reach and remove filter, replace drain plug, new filter, fill up...my only issue is that the sight glass is such a pain in the a**ss to see when you are refilling with oil
It is only a bit harder than changing oil on the Suzuki TLs..and the oil thing easier than that was just not doing it..:badteeth:
If you want a real excercise in frustration..try doing a filter and oil change on a Honda CBR 1100XX........
