well my tire pressure is f38/r40 i weight 215 and havent adjusted anything and i keep drifting out of 3/4 lean corners its got me all messed up no confidence now
dazam I run on the street 32 PSI front cold 30 rear!
all tire PSI is for is to control tire temp!
that’s it nothing more nothing less! people worry too much about what the # on the side of the tire reads
i.e. 45psi …yeah if it's 115 degrees outside! You want your tires to run at optimum temp! and if it takes 45psi, well ok them! but it may only take 25PSI this all depends on how you ride and what your ourside temp is!
PS and too cold of a tire will cause your sliding issues you say your having!
