1 - 3 of 3 Posts
Just reached 15000 mi and did a valve clearance ck, alls good and in spec. Thought I would Degree the cams in since I had it all apart, ( problem #1) this thing is a bitch to rotate over to reach TDC and the only bolt to use is the tiny 8mm on the crank senser, is there a better location to rotate the motor.
the plugs are all out, the engine rotates pretty tight and all I have is a little 8mm bolt on the crank trigger side of the crank and worse yet I have to use a longer bolt for my degree wheel which isnt as stout as the factory bolt, any set up Ideas would be great.
1 - 3 of 3 Posts
