I've searched and searched but can't find any related issues to answer my question. just got my 2015 two weeks ago and the first 1K miles has been great but now at 1400 miles it feels terrible when getting on and off the throttle. Not sure how to explain it other than it feels like a rear diff with a ton of gear lash. The transition from off throttle to acceleration is no longer smooth like it used to be. Makes me nervous getting on and off the throttle near corners. The throttle cables seem to be adjusted properly. Thought they do seem to loosen up later in the ride. Chain has no more that 1.25" slack. The chain was pretty tight, in my opinion, when I bought it new. How tight is too tight? Manual only says NO MORE THAN 1-1.25" slack. Coming off Throttle by wire belt drive bike so chains are new to me.
This happens with every new bike. I have owned dozens of new motorcycles and the chain and driveline just "opens up" a little after a thousand or so miles. Part of it is obviously the throttle cables, part is the chain slack, but also the cush drive dampers in the rear wheel loosen up just a tad and you can feel that.
Also, riding techniques have changed since EFI was introduced.
No longer can we keep the throttle closed to the very bottom of the turn at max lean and then crack it open like we could with a well-set up bank of CV carbs. You must train yourself to at least get the slack out of the throttle cables BEFORE the bottom of the turn (max lean) so you are back on the gas - albeit the slightest amount - to prevent that driveline shock that upsets the bike.
It's a differnt technique; took me a couple of years to relearn how to control the throttle on these new high-powered, EFI bikes but there it is.
One last thing, the Kawasaki exhaust backpressure valve is operated by cables and they do get loose. This also has an effect on throttle pickup.
To recap:
-chain gets loose
-cush drive loosens up
-throttle cables get loose
-exhaust backpressure valve cables get loose
Because of the cush drive it will never be quite as tight as when new no matter what you do.
