1 - 9 of 9 Posts
2018 ZX10R
Hey all, just received my domino xm2 throttle and universal cables. I haven't tried to install them yet and am waiting on a new intake/fairing stay to arrive before routing. I noticed the cables come out of the domino housing on what appears to be the bottom side (opposite of domino logo). Has anyone installed this throttle, how did you route the cables, out the bottom, or over the top like stock.
Can you post photos of the items? Maybe we can offer a solution without having owned them.
It's just an issue with the logo showing in the wrong place then you can rotate it on the throttle tube. Blast some compressed air between the rubber and the tube to separate them and rotate. If the rubber is glued onto the tube then carefully run a small screwdriver between the two to break the adhesion first.
2018 ZX10R
Discussion Starter · #3 ·
Automotive tire Motor vehicle Automotive fuel system Bicycle part Bicycle handlebar
Hand Automotive tire Automotive lighting Motorcycle Motor vehicle
Oh, I thought you meant the rubber logo. I wasn't familiar with this part until now.
You should be able to flip the cam mechanism in either direction (and choose to have the printed logo up top) but you just need to ensure that the cables are being operated in the correct orientation and switch their positions if they aren't. Open up your OEM throttle housing and you can easily see which cable gets pulled when you turn the throttle counter clockwise. If it's doing the opposite then just switch the cables in either the Domino unit- (probably best) or at the other end.
2018 ZX10R
Discussion Starter · #5 ·
Yeah I would just copy OEM but it was fully smashed cables ripped. I'll figure it out and report back. Just waiting for my front stay for the dash and upper fairing before I route
I had a brain fart earlier. Switching the cable positions at the throttle body wouldn't be a good option since you'd have to switch the cable guides along the way.
If you're not sure open up the Domino again and take a picture of the cam from the side while holding the logo right side up. We should be able to point out which cable to goes where.
2018 ZX10R
Discussion Starter · #7 ·
That part is easy, only one way the cables can install. I was just wanted to see if anyone has installed one and if they had specific routing tips.
Hopefully somebody has their fuel tank off already and can trace the cable routing for you.
1 - 9 of 9 Posts
