1 - 9 of 9 Posts
I'm going to be replacing my OEM rear sets with sato, it appears I need to put in a pressure switch for the back brake light. Do I need a coarse or fine thread pressure switch?
2013 zx10r abs
2013 zx10r abs
When you purchase the Sato Rear Sets they will come with the correct Pressure switch already in the box where needed.
If they do not come with the kit then you re-use the stock switch.
Brake fluid will leak while you do that and you will have to re-bleed the system once the pressure swich is installed.
That's kinda what I figured. Sounds pretty straight forward.
1 - 9 of 9 Posts
