1 - 7 of 7 Posts
I have been riding this bike regularly (22,000 miles, oil is good) and a few days ago I started it up and walked down to my truck to get my helmet. All of the sudden it made a loud screeching sound that is best described as what a loose/worn belt on a car makes??? I called a few people...put it in 6th, rolled it backwards about 10 feet and it cranked up normal for about 3 seconds then did it agian...
It is not frozen, it will start but makes this CRAZY LOUD sound...any ideas before I try and find another motor????
Of course this happens when the weather is PERFECT!!!!
Thanks for any info!!!!
Gen2 Ripper
You may want to put the bike up on a rear stand and see if the rear wheel takes off spinning from internal friction during that sound. It might be clutch to mainshaft bearing and also the countershaft.
+1. There's a thread I'll try to dig up on hear about one of the trans shaft bearings causing noise from friction though it was a constant light audible sound, not a "just let loose/seized bearing kinda sound. I would suspect clutch or tranny if it's not the starter sticking(would do that right away after hitting button). Let me try and dig up that tranny thread.....
Now that u say that I thought I felt it slipping a little for about a week before this happened???
Thanks for the info, I will try that ASAP!!
Gen2 Ripper
1 - 7 of 7 Posts
