1 - 3 of 3 Posts
Hi All
I race speedway sidecars and am currently running a Gen 2 2006 ZX-10, I am currently looking at a project to pretty much just throw money at the engine
I am racing on dirt so I am not looking for horsepower that much as this will just cause the rear wheel to spin, I am really after torque
What I would like from you guys is the ultimate engine from torque in regards to parts and such ... and if possible links to sites where I can buy them
So something like the below
Crank -
Cams -
Plugs -
Pistons -
Etc...
Thanks All
Adam
Team Thompson Racing
Go Fast or Go Home
Http://www.teamthompsonracing.com
Do a stoker crank shaft. That will get the power down to a lower rpm and increase torque. You can have custom cams ground to make more torque also. Then get the compression ratio around 14/1(needs race gas). That will get you a good start. Then you want an exhaust tuned for midrange as most are tuned for high end.
What is a stoker crank shaft? or where can I get one? ... yeah got custom cams, ground to torque ... compression ratio with the new rods and pistons I am putting in there is currently 13.5/1, we are only allowed to run methanol though? ... yeah will have to swap out the current exhaust on it
Thanks for your reply
Adam
Go Fast or Go Home!
1 - 3 of 3 Posts
