negative. I'm sure the motor works off some kind of resistance and when the ecu doesn't "see" that resistance (either from it being unplugged or for any other number of reasons) it then throws the fi light. I wonder if duplicating that resistance would be enough to keep the light off.Couldn't a tuner turn it off?
That stinks, guess you are either stuck with Ivans or a light.negative. I'm sure the motor works off some kind of resistance and when the ecu doesn't "see" that resistance (either from it being unplugged or for any other number of reasons) it then throws the fi light. I wonder if duplicating that resistance would be enough to keep the light off.
You know, your right, it IS just a resister, it shouldn't be hard at all to create a small resister to replace the servo...negative. I'm sure the motor works off some kind of resistance and when the ecu doesn't "see" that resistance (either from it being unplugged or for any other number of reasons) it then throws the fi light. I wonder if duplicating that resistance would be enough to keep the light off.
Didn't someone fry their ecu doing this?You know, your right, it IS just a resister, it shouldn't be hard at all to create a small resister to replace the servo...
I think I'm going to give creating this thing a shot. Ive got some time this week, so I'll see if i can come up with something. in the immortal words of my hero, Jeremey Clarkson, "How hard can it be?"
:+1: i would think if you could figure out how much resistance you need. you should be able to by pass it. personally i don't have the money to throw down just to get the light to go off. please lemme know what you find outYou know, your right, it IS just a resister, it shouldn't be hard at all to create a small resister to replace the servo...
:+1: you and me bothAny solutions yet!? I need a new butterfly valve actuator or a better solution to spending 235$$ for something I no longer need!
