Good day
Wondering if any would know whats wrong with my tach.
What happens is that when I turn my key, the RPM should blink 3 times but mine does not light up at all.
This bike was bought brand new and it was normal until one day my mate turned the key on and noticed it did not blink 3 times as usual.
This happened after I replace the ESD with ohlins aftermarket manual. The connector is left under the tank so the ESD light is on but I don't mind that.
Thing is the abnormal tacho did not happen right after removing stock ESD. It happened days after that so I am not sure if removing the ESD is related..
Apart from tach no flashing 3 times, bike operates and runs normal
Any tip would help
Cheers!
Any tip would help
Cheers!
