1 - 7 of 7 Posts
Hi!
I’m going to get the bike properly set up on a dyno, and I need to find the tach signal for the dyno.
Is there a way that doesn’t involve removing the airbox?
Rgds
/J
Generally the sensor is an alligator clip from the dyno that clips onto usually an ignition wire above a coil pack and is usually accessed from the side. To make it easier for the tuner, remove one or both side panels
Any one of the stick coil leads will do which go back to the ECU individually.
Cylinder 1 Black
Cylinder 2 Black with Red Stripe
Cylinder 3 Black with Orange Stripe
Cylinder 4 Black with Green Stripe
Discussion Starter · #6 ·
Cylinder 1 Black
Cylinder 3 Black with White Stripe
Cylinder 4 Black with Orange Stripe
Sweet, just what I hoped for! Which one of the three connectors would I be looking at...?
Rgds!
/J
Rgds!
/J
DOH! I was originally looking at the diagram for the gen4. So I removed the picture and changed the wording (cylinder 3 and 4) to reflect the proper colors. 1 and 2 did not change. It's on the left most harness (when you're sitting on the bike) kickstand side.
Only reason I caught the mistake was when you mentioned there were 3 harnesses. Gen 4 only has 2. Sorry about that.
1 - 7 of 7 Posts
