1 - 5 of 5 Posts
I found these settings for the suspension, can someone please clarify to me exactly where the screws are for each of these settings?
My confusion is whether the rebound is on top or bottom of the forks, and rear shock / where is the comp / damping - top / bottom ? :dontknow:
settings are:
ZX-10R ('05) 5/05
Front preload: 5 lines showing
Front rebound: 4 clicks out from full stiff
Front Comp: 7 clicks out from full stiff
Rear Preload: 14mm thread showing
Rear Rebound: 1.5 turns out from full stiff
Rear Comp: 3.5 turns out from full stiff
fork rebound = top
" comp = bottom
use a flat screwdriver to adjust both
_____________________________________
shock rebound = bottom
" comp = top
settings are:
ZX-10R ('05) 5/05
Front rebound is top, comp is bottom.
Rear rebound is bottom, comp is top. :mrgreen:
GAAAWWWRRRR....:thumbsup:
1 - 5 of 5 Posts
