1 - 5 of 5 Posts
Mine broke is that something that I can replace...manual says factory set... or do I need a new throttle body assembly or can the motor be ran with it unplugged.
Need a new tb assembly. Can't replace.
Engine won't run without it (or won't run worth a s#!t even if it does) because secondary butterflies are fully closed in their "off" position.
You can remove the flaps. Engine will run fine if they're gone completely. Will throw a code but won't limp mode.
Discussion Starter · #3 ·
Is that the top butterflies or bottom butterflies? We run with our top ones closer to breather removed. But I did order a new TB last night.
1 - 5 of 5 Posts
