1 - 11 of 11 Posts
Ok so I have the swingarm here and I'm ready to throw some clear coat on it (it's already sandblasted) I just wiped it down with rubbing alcohol to get the fingerprints off it but I can still see them on there. Any idea what I can use to clean it up real good before I clear it?
What about some laquer thinner?
Custom Powder Coater
Cool thanks pearl!! I've noticed there's some little speckles of paint here and there (not much) will MEK take that off too? And what do you recommend for clear? I just grabbed some rust o leum clear
will that stuff strip the frame finish? or just as a cleanup after blasting?
If u want strip use aircraft stripper.. its only paint so it works pretty good at removing it MEK is more of a cleaner but it will remove finishes if it gets on it..
1 - 11 of 11 Posts
