If you want to ride like an idiot, it is best you do it in rural areas. If you decide to ride like a Joe Rocket in the city and on interstates, you better be prepared to run, and be prepared for the consequences of a felony.
Best advice in any situation of getting "busted" is to immediately pull over in the safest area as possible. Consequences of evading are multiples worse than just pulling over. Just pull over and most likely state prosecutors will reduce the charge in your favor (assuming you are not a repeat offender), and given the circumstance and officer, you might get away with a warning.
Know what you are doing, who it is impacting, and the consequences.
