So, I have an 08 with around 14K on the clock. I will turn the key to "on", switch the start/run button to "run", and press the start button and the starter will not begin to spin from anywhere from 1 to 5 seconds. I hear the master control relay click as soon as the button is pressed, and the bike turns over and starts as normal. The battery was tested professionally and it was good. The only thing I can think of is perhaps the starter is going bad, or maybe the master control relay isn't delivering the voltage right away. This issue is intermittent and only seems to occur when the bike has sat for a day or two, or if it's cold outside. The standing voltage on the battery prior to starting is around 12.55 volts. It dips just below 10 volts when starting. Any help is much appreciated. Thanks fellas.
