1 - 2 of 2 Posts
Hi
I have installed a kit ECU and harness on a zx-10r 2013. There seem to be a few problems:
1) I am getting error codes 1b - 3C, which I understand is ABS and steering damper. This seems strange because the ABS is removed and the race ECU certainly does not support this. This is the same with the steering damper (which is now manual).
2) The ABS Indicator Light and the Warning Indicator Light (Yellow) (just beside) are both on when driving.
3) The Warning Indicator Light (Red) blinks when the ignition is off.
4) I am not able to adjust the shift light, by pressing upper and lower buttons while blinking etc. according to the user manual. It went up to 14000 but does not restart on 9500 as it should, when holding the second button down.
I would be grateful if anyone could shed a light on any of these issues. Thanks!
Regards,
Aksel
From previous experience (with my Gen 5) all units must be plugged in, switched to off with the kit stuff then can be removed.
On mine I removed the SD and then turned it off but couldn’t get the CEL off till it was plugged back in.
1 - 2 of 2 Posts
