1 - 9 of 9 Posts
For those of you NOT using the kit ecu, did you leave the black bracket in there along with the rear seat latch?? yes i did search, a few different things :biggrin:
Always On Mod
nope, i pulled the seat latch bracket out, and then zip tied the tip over switch to the fuse block that sits by the ecu
I removed the bracket and drilled two holes in the center of the in the subframe and bolted it down.
i was just looking at that very same thing last night, i was curious if it would hit the bodywork or not, i'm assuming not.
Discussion Starter #8
1 - 9 of 9 Posts
