Story is that I sent out my steering damper to be rebuilt, got it back and everything seem to check out (smooth, no signs of leaking). Install it back on the bike per the service manual, leave it about half way through the setting, works great. So i go to crank it all the way up this morning and I notice there seems to be a bit of play in the damper before the force is applied. Did not think anything of it but when I come to a stop i notice there is fluid under my triple tree on the right side of the frame. So what went wrong is my question? To much fluid? Should i just remove it for now? This is for a 2012 if that helps at all and the fluid is coming from the gold, not where the rod comes out.
