1 - 11 of 11 Posts
Hey I was thinking of replacing the stock lines. Is it a pain in the ass or is it worth it for the performance aspect? Thanks
It's worth it. A little paint to bleed but not too bad. I've done it several times now.
Totally worth it.:thumbsup:
They can be a pain to bleed,I did mine manually.
Total time for the front end 2 lines from the master was a hour (Galfer)
You will definetly notice a difference,it gives you a solid constant brake under heavy braking.
I used to notice under heavy braking the handle would fade with the stock lines.Maybe due to swelling of the lines.But the stockers looked pretty solid also.
The Galfers ran about $100.00 for 2 lines from the master,custom cut for your model year specific,no excess line flopping around up front.
I bought Galfer greens for the green 06 I own.
just did my rear brake line with spiegler SS brake lines... they look sick and it took about 20 minutes....
i have the handy dandy mity vac pump and that things is the balls... bleed the brakes in literly about 5 seconds
i recommend buyin that thing... its just an awesome tool
Spiegler and Mity-Vac combo here too. Awesome combo. Yea, it's worth it. :thumbsup:
agreed, good mod, just lay some towels all around the resovior so it dosent get brake fluid on the paint.
1 - 11 of 11 Posts
