1 - 6 of 6 Posts
At about 4-5k it should be 50-60v AC
Gotta check ac from stator not dc. You test a pair of leads at the plug when disconnected from regulator. Total of three tests. Must be done at higher rpm not idle.
Alright I will do that probably today when I get home. I did not know that. So it should be between 40-50ac at 4-5k rpm. Anything else I should know?
1 - 6 of 6 Posts
