1 - 12 of 12 Posts
Discussion Starter #10
I took a flat blade screw driver and pryed it out around where the bolt holes are. It would probably be easier if you had 2 screw drivers the pry it out. I just pryed it, and held it on one side then pryed the other side till you can get a good enough grip with your fingers.
Thx got it man I been having bad luck putting my motor back together. I didn't want any more set back.
Discussion Starter #11
not stuck, nothing holding it there but strong magnetic field, just pull harder, put some butt in it toney.
Lol Jim u should have seen me I was sitting on the floor with the cases between my feet pulling it lol I was pull hard as I can lol I got it thx men
1 - 12 of 12 Posts
