1 - 2 of 2 Posts
I have a 2005 ZX10
I’m trying to figure out is there a such thing as a feel pump priming but still not being able to work properly ....
I noticed my feel pump cuts on but the bike will not run.....
But if I spray starter fluid into the intake the bike starts and runs with no problem.
So my question is is it possible for the fuel pump to prime but still not work Or do I have another problem going on?
yes, seen it more than once. also check injector signal from ecu which is ground pulse and common colored wire on each inj should carry 12v ign switch on.
1 - 2 of 2 Posts
