1 - 5 of 5 Posts
Hi guys
Want to find out.have a 09 zx 10 and when you press the starting button theres a knock and after it started its gone and running fine...but does not do it every time when you press the starting button .installed a new starting clutch but still does the same thing .need help
Did you inspect the starter motor, it could be worn causing play at the spine, it can be turning with full power but have worn bearings at the same time, it could also be lose on the 2 mounting bolts but normally that would give you a bad earth and it would turn over slowly but at the same time inconsistently.
Discussion Starter · #5 ·
The splines on the starter looks fine and not much play...wil open up the starter and check the bearings butt if i remove the torque limiter gear and press start with just the starter spinning all sounds fine...will post a vid when i get home
1 - 5 of 5 Posts
