Have any of you successfully installed a Starlane Engear on your ZX-10R?
I have a 07 that I am having a problem correlating the bike schematic to the Engear wiring. Here's where I'm stumped.
RPM Signal:
I cannot find the RPM sensor wire on the schematic. I'm guessing it may be the Brown/Red wire that runs directly between the gauge cluster and the ECU.
...or should I tie into the Crankshaft sensor wire? If so, should I splice into the Black wire or the Red/Black wire.
Thanks for any help you can provide.
RPM Signal:
