1 - 5 of 5 Posts
how many teeth does the 2006 10r have in the rear stock???
i am looking at going up 1 MAYBE 2 in the rear.
i already went down 1 in the front.
will there be enough chain if i go up 1 in the rear? maybe 2?
anyone can help me on this or have done it?
MIA Ex-Mod
I know stock is 40 rear on the 06. You may be able to go up 1 but def. not 2 on the stock chain. I really doubt you will be able to get the stock chain on the 41 but it may be possible if the chain has stretched enough. But if the chain has stretched enough then I personally would change it out.
Tread
if you change it to 16/41 the OEM chain should work but if its got many miles on the chain it too should be replaced.
-1 in front (16t) would allow you to use stock chain and afford you a smidge of wheelbase...
1 - 5 of 5 Posts
