I have the gen 5, but was hoping some of you with the Gen 4 may have installed it and run into this and figured it out.
So I installed this kit: SPORTBIKE LITES Dual HID HIGH-LOW H7 Sport Bike Headlight Bulb Conversion Hi/Lo Kit
I talked to them and they said it should fit fine. It does and it looks great! My only issue is the operation.
It's supposed to be both on for low beam and then the bulbs flick up slightly for high beams. Mine is currently no lights on low beams and both come on for high beams. All the wires are different plugs, so it's impossible to mix them up, so I'm not sure what's causing it. Any ideas?
