Hello all. I have a 2012 ZX10R ABS that suddenly has developed an issue with a speed sensor. When I ride the speedometer will jump around and the traction control will randomly fire causing light stuttering. The few times the F1 light came one with the blinking Traction controls it gave a flashing code of 24 then 27.
Code 24 is saying speed controller malfunction. I can't find anything for code 27. I have pulled the wheel sensors and they are clean. The wiring shows no damage. Any suggestions? Could it be a battery issue? It is an older battery, but it fires up. Bad ECU? Thanks for your help with this.
