1 - 8 of 8 Posts
Ok so I received my SpeedoHealer last week and just wanted to ask all of you how you chose to calibrate it. Did you do the 60mph test or did you go off of the gearing you had on it? Thanks in advance.
Thanks Ill def. check that out.
I used the calculation method...was thinking about trying to fine tune it a bit with GPS.
I also did it using my garmin. I rode till my speedo read 90 mph. GPS read 73. Went on their website and used precise calibration and gave me a -18.9 error. I entered that in my speedohealer now it is dead on at any given speed confirmed with my GPS. I'm 1-/+2 gearing.
I used my Garmin also. The "estimated" calibration will get you close to the actual mph once you input your tires sizes and gearing but if you use a GPS, the "precise" calibration will get you spot on.
i went to a 16t with the stock 39t in the rear on an 04, i havent got the speedohealer yet but does anyone know how much im off in mph:dontknow:
1 - 8 of 8 Posts
