1 - 8 of 8 Posts
Hey guys. I just installed a SHv3.0 + Harness Kit on my '07 ZX-10R but I am not getting any lights flashing on the unit? I confirmed with a multimeter that the single 12v Red wire does indeed have 12v. But no lights on power up or when spinning the wheel by hand like the instructions say. :dontknow: Any ideas? I emailed Speedohealer and am waiting a response but thought maybe someone else had run into this. Thanks.
Needs 12v and a ground. If it's non responsive then Speedohealer should hook you up, they have excellent customer service but e-mails might take a day or two.
Depends how you checked the 12v, if you went from battery Negative to test that doesn't prove you have a good ground at the UNIT. I would test with a TEST light or multimeter on PIN 2(ground) to Pin 3(12v) to see if you can get a 12V measurement that way with the connector still in place on the Speedohealer side and measured at that point.....then you can go from there depending on what you get.
bloo
Rent this space
Dunno , but what I do know is that your avatar depicts the greatest motorcycle racer ever to have walked the planet.
Found it! A damn small piece of clear platic from the wrapper was inside the 4 prong connector that plugs into the unit. Thanks guys.
So I assume you tested for the 12v before the connector and were not sure about a good ground there to the Plug?...anyway good deal Dan :thumbsup:
Discussion Starter #8
Actually I was checking at the 4 p connector, but I think the probe on my multimeter was going in deeper (past the plastic) than than what the actual male pin was able too. A pair of tweezer and out it came. Thanks.
1 - 8 of 8 Posts
