1 - 8 of 8 Posts
I'm trying to set the 2nd setting on my speedohealer. I want to set the other setting up so I can just use the button to switch from one to another if I change set ups such as sprockets or anything like that. I can't seem to figure out how to though. Any help would be appreciated. Thanks.
So how do you set the 2nd setting?? Also is that 2nd setting changeable through the button?? When I try and put the other setting in it only shows the L and the - so i'm not too sure how i'm supposed to get to that other setting.
Don't like to use the interweb?
http://www.healtech-electronics.com/docs/SHv4_UsersGuide_en.pdf
"3.5 Switching between A and B calibration value
Press SET until the active memory bank ([A] or ) is displayed and keep it depressed for one more second, until the value switches.
�� When you program a calibration value (chapter 3.2), you can program the value in the active memory bank only."
I tried looking online and here before I posted... apparently not good enough though... :thefinger
Either way. Thanks a lot man. I appreciate you finding that and sharing. :eek:ccasion1
1 - 8 of 8 Posts
