Today I removed my rear disc rotor in order to perform a rear brake delete. Calipers/lines and all have been removed along with the rear disc but I kept the bracket in place since I don't have a rear delete spacer yet.
Anyway during my first ride after putting everything back together the bike constantly throws a code P2158 (speed sensor) and the check engine/the triangle yellow light comes on. Traction control disables and my QS(Upshsifts stock working). Since I have a Aim MXK10 I'm able to clear the code from the instrument panel, but after I ride for another 5-10 minutes the bike throws the codes again. I rode back home and made sure the speed sensor was secured properly and it's definitely torqued down correctly. Also the speedometer works properly and displays the speed even after the code pops up.
Does the rear brake rotor work in tandem with the rear speed sensor? I performed my rear delete in sections over a period of a week and finally was able to get a air gun to remove the rear brake rotor today...so I know the code is related to this part because the code issue didn't show up until after I removed the rear brake rotor.
Any help would be great;y appreciated.
