So I'm doing my sparkplug/airfilter change at 15500 miles. From what I can tell someone else has been in here (I hope lol) I bought the bike at 7500. So if your facing like you would sit on bike when I removed gas tank there was a breather hose on the right hand side and the other nipple on the other side had no hose or anything sealing it. Can I cap this? Or does it need a legit breather hose like the right side?
Next question is when I removed airbox the center 5mm Allen bolt dead center of box (the one in the deep channel) was not there. Do I even need to bother replacing it?
The clamp on the bottom of the airbox to the throttle bodies was not tight it was loose. Sloppy previous owners
Thanks!
Thanks!
