if i read the marketing text, than the 2017 RR have:
trackfocused gear ratio (2nd to 6th shortened)
M50 Brembo
and lightweight marchesini wheels
if i compere the tech specification on kawasakis USA hompepage and on the german Kawa homepage, than i am suprised:
1. The simple R has exactly the same gear ratio in every gear
2. the simple R has the same M50 Brembo Calipper and same Brembo zylinder
3. even the weigth is the same 206 kg for both R and RR (only the simple R without ABS is 204 kg)
the gear ratio numbers i even controlled today in a service manual, i was shocked but all article number is the same for all gears in the simple R and also in RR
What is the TRUTH ????
thanks
Gabor
M50 Brembo
thanks
Gabor
