1 - 11 of 11 Posts
Anybody know what kind of sparplug needs for zx-10r 2004 ???
Iridium I know, NGK I know, but are this the one with resistor in the plug ???
Thanks.
Yankee Racer
Thread moved. I am sure if you posted up in the sponsor section that one of our sponsors could hook yah up nicely with what you need as well.
JJ
Supercharged Mod
Not worthwhile. CR9EIX is the same plug but without the 1mm extended tip that the CR9EIA has, and you can get or order the CR9EIX from *any* NGK dealer. They cost way less, and as far as I can tell, there's no difference in operation ... Heck, if you want the CR9EIA-9, you can probably order those from an NGK dealer, too.
Canadian Tire, UAP/NAPA, etc all deal with NGK.
ngk also makes a racing plug for the 10. at $40.00 a pop. anyone knows if it helps any.
The racing plugs or not worth while on street bikes as they tend to foul from what I have read.
For how hard it is to get to the stock plugs I would not do it.
1 - 11 of 11 Posts
