1 - 5 of 5 Posts
Does not drive into smoke
They basically use more exotic materials to with stand higher compression higher temps and high rpm's over a long period of time.
Sent from my DROID2 using Motorcycle.com App
Does that mean that normal plugs would not last (or perform optimally) for the duration of a race? I have in mind professional race setting, where, I guess, the plugs are replaced after each race... Does the use of race fuel make a difference here?
They require less voltage to fire but unless your running a twin turbo 1000 hp motor or running wide open for 500 mi or anything where your beating the dog snot out of a engine for a period of time there is not a advantage to running them. Just use what came in the bike.
1 - 5 of 5 Posts
