Video of said noise? Highly doubt a front sprocket is going to make a noise loud enough given its fixed in place, either the chain is munching the swingarm if there is no plastic guide, or it's something internal given all the internal gears run along the same axis as the front sprocket, that plus internal is the only place that has actual movement of the gears and dogs etc.I doesn't. It literally sounds like the front sprocket nut is loose and the sprocket is in there with an empty coke can full of pennies. I'm exaggerating of course but it's loud enough to make me want it to stop. I'm not above saying it's me looking too much into stuff but I just wouldn't expect this kind of noise on a bike with 6k on the clock. The mechanic is a trusted one around here and she said it's that loud because the dampening equipment is not there. Going to order the vortex steel front and back and an RK 525 z3d. If it's still there, maybe I'll just order and re-install the dampeners. Been on gsxr's for over 11 years and this noise is foreign to me. Not believing it's just aftermarket parts, non-quality or quality parts.
Came in the mail along with new chain and sprockets. Took a look for myself and it's not actually missing at all. Further look into sprocket covers and it doesn't appear they come with insulation in the cover. Not even sure what she was talking about at this point. Waiting on a socket and I'll find out if the noise is from any of that.If you were missing the nylon chain slide pictured above, for sure you were hearing noise from the chasing rubbing directly on the swing arm, can’t you see in there the aluminum being worn away?
Sprocket cover has no insulation, that was the comment from her that I was curious about, and I had hoped to clarify it and prevented unnecessary expense.Came in the mail along with new chain and sprockets. Took a look for myself and it's not actually missing at all. Further look into sprocket covers and it doesn't appear they come with insulation in the cover. Not even sure what she was talking about at this point. Waiting on a socket and I'll find out if the noise is from any of that.
